Newbury/Thatcham
Posted: Thu Jul 07, 2011 2:17 pm
by StuartL
I've just joined CB 30 years late having fitted it to my Pinzgauer for use in offroad trips. I overlooked buying a SWR meter. Is there anyone kicking around Thatcham/Newbury who has one I can borrow to tune it? With a virgin installation I can't elicit a response but I figure my SWR is probably way high at the moment.
Thanks,
Stuart
Re: Newbury/Thatcham
Posted: Thu Jul 07, 2011 4:10 pm
by Guzzy
That is way cool!
Tell us what CB equipment you are trying to install?
Specifically, which antenna?
Posted: Thu Jul 07, 2011 4:22 pm
by StuartL
At the moment I've "sprung" for a basic springer. Being a serious off-road vehicle the antenna has to be very resilient but cheap enough that I don't break the bank if it gets damaged.
Since the original post I have managed to get a radio check from a very very local lorry driver so I know the CB is good for 20 metres or so
Still needs tuning and fitting properly.
Rig is a Kernow 2100GTL bought for a packet of peanuts on ebay, antenna cable is RG58 with PL259 temporarily attached. When I've built the rig housing I'll solder the antenna wire on properly at the correct length.
As the vehicle is 24v I needed to drop the voltage. I didn't want to pay the extra cash for a 24v capable rig when there are so many 12v rigs going for much less money on ebay. I bought one of the £7 24v/12v 30A voltage droppers and have (again temporarily) wired it into the main switched 24v line. Again when the housing is built the voltage dropper will go behind the housing and also power a couple of cigarette lighter sockets and USB ports for other power needs.
I haven't yet figured out a handle. In the days of the Internet before the world-wide-web (yes, that did exist) I used to be known as 'Static', but that seems a little inappropriate for a radio handle
Posted: Thu Jul 07, 2011 6:25 pm
by Guzzy
Well, you will be pleased to know that the 'springer' is basically good to go. They are pre
swared (love that word!
). Which means they are cut to be resonant for both CB bands.
You should be OK to just plug it in and use it ...
but ... you might find that the antenna positioning on the vehicle will effect the SWR, so it's still worth checking.
It also shows if you have accidentally pulled the coax out of the mount or PL259 plug (does happen). I'd buy a cheap and cheerful SWR/Power meter and install it permanently, just leave it in-line. That way you will hopefully notice if the meter suddenly starts swinging all the way over into the red.
Until you get an SWR meter, you should be OK to operate. Just don't sit there TX'ing for hours, just in case.
Oh, and 'Static' is about as appropriate as you can get for a CB handle.
Posted: Fri Jul 08, 2011 6:35 am
Posted: Fri Jul 08, 2011 9:51 pm
by Guzzy
stampman wrote:never leave swr in line you lose power through it set swr then take out
Every connector in-line accounts for about 1/3 of a dB of signal loss. In truth, you should remove all unnecessary connectors/devices between the radio and antenna.
HOWEVER...
An in-line SWR meter will instantly show up the fact that your coax has been pulled out of your antenna on the top of your vehicle by a snaggly branch, or that you have crushed the coax when you slammed the boot.
In my opinion, a dead short from a damaged coax or ripped off antenna is worse than the relatively small losses (and small possibility of causing inadvertent RF interference) you get from an in-line SWR meter.
Each to their own though.
Posted: Sat Jul 09, 2011 8:32 am
Posted: Sat Jul 09, 2011 10:42 am
by Guzzy
stampman wrote:ok leaving in line if you are running 100 watts not so good on 4 and if some thing does happen as you say you would notice straight away had all them problems in the 35 years been doing cb and you do notice very quickly
... and I'm only saying as I've found since November 2nd, 1981, when my Mum finally allowed me to buy my own CB radio, although the licence had to go in her name!
I've seen PLENTY of CB radios that have been damaged because the user didn't realise they had a dead short in the coax or a bad or broken antenna, and on three separate occasions - because the antenna had fallen off!
Each to their own. Your mileage may vary, etc, etc, ....
Posted: Sun Jul 10, 2011 9:36 am
by banjo
I am based a little outside of newbury but can be found driving around newbury/thatcham, I have ordered a meter for mine, as soon as it arrives you're welcome to use it.
Olly
Posted: Mon Jul 11, 2011 8:34 am
Posted: Mon Jul 11, 2011 9:26 am
by StuartL
What are common channels around this area? I've not heard much on ch19 in the last week or so?
Posted: Mon Jul 11, 2011 6:56 pm
by banjo
I haven't heard much of anything in the last few months, I thought I was all alone. I just keep it on 19, occasionally flip to 14 or 21. I'm not in the car for long periods of time though so might just be missing all the traffic.
Posted: Wed Jul 13, 2011 8:17 pm
by banjo
Got my meter delivered today, not got a patch lead for it though, if you have a patch lead then you can borrow it, otherwise you'll have to wait til I get round to ordering one.
Posted: Sat Jul 23, 2011 9:32 pm
by rock steady
you are missing the action bud... there are other breakers on around thatcham ( i am when i get called to my head office in pipers lane). you should be able to hear the guys over in camberely, bernie over at maidenhead, barry the boot in slough. where have you mounted that stinger on your pinz, coz if too close to a upright panel of metal ,it will effect your swr ...
