power supply
Posted: Sun Jul 24, 2011 11:49 am
by billathome65
Is this power supply to strong for a Midland Alan 78 plus or other CB radios?
WATSON POWER MITE NF ham cb power supply 12v 13.8v 22A
Cheers Bill
Re: power supply
Posted: Sun Jul 24, 2011 2:27 pm
by Guzzy
No.
It's more 'powerful' than you need, but it will do the job admirably.
It's rated for 22 Amps, but it will only provide whatever the radio 'pulls', up to the maximum of 22 Amps.
It's regulated to provide 13.8V as long as you don't try to 'pull' more than 22 Amps from it.
Your Midland will only be 'pulling' about 2 or 3 Amps.
Re: power supply
Posted: Sun Jul 24, 2011 4:02 pm
by billathome65
so if i see a 3 5amp cheeper then it makes no difference?
bill
Re: power supply
Posted: Sun Jul 24, 2011 6:51 pm
by Guzzy
billathome65 wrote:so if i see a 3 (or) 5amp cheeper then it makes no difference?
bill
As long as your radio (and any accessories you may plug into it) 'pull' no more than 3 (or 5) amps.
The model I have is rated as a 7 Amp continuous (10 Amp for 50% duty cycle, 12 Amp Surge), power supply. Just in case I need it to power any accessories (ahem...).
Re: power supply
Posted: Mon Oct 10, 2011 5:46 pm
by radiomaker
I look at the CB power supply. The output is typically 13.8 volts. You bring a rig out of the car into the house. You were running it off a 12V car battery, now you connect it to this power supply. Am I missing something? All I could think of was that 13.8V was a off-load figure that would drop to the true 12V on-load.
Re: power supply
Posted: Tue Oct 11, 2011 6:32 am
13.8 is the voltage a car runs at when charging so a dropper should be 13.8 or there about as well for peak performance
