Fitting CB in Renault Kangoo
Posted: Tue Sep 06, 2011 8:25 pm
by WOODY R
Hi everyone, I want to fit my CB into my Renault Kangoo. I want to fit it on the underside of the front parcel shelf, above the front seats. The problem i am going to have is, how can i run the power to it, there are not any covers over the front door pillars to run a cable in, there is not anyway i can run a cable either side of the windscreen, as there is only the windscreen rubber.
The arieal, i am thinking of using a Dome mount and drilling a hole in the roof, is this a good idea, or will it leak, would it be better to put silicone round it ?
Any help and advice would be much appreciated
Many thanks
Re: Fitting CB in Renault Kangoo
Posted: Wed Sep 07, 2011 8:59 am
probably better to use a good car radio installer to drill and fit the antenna as they have the expertese to hide the cable
