So, if we get 12W SSB.....
Posted: Mon Oct 03, 2011 11:30 am
by Morat
What sort of difference is that likely to make in the range achievable?
Would we need different antennae?
fingers crossed!!!
Re: So, if we get 12W SSB.....
Posted: Mon Oct 03, 2011 1:20 pm
NO SAME ANTENNA
Posted: Mon Oct 03, 2011 8:42 pm
by porky.69
just more idiots :cry: on 555
Posted: Mon Oct 03, 2011 11:27 pm
by Adriano9966
:D you will not require a different antenna as its just a choice of different modes rather than a change of frequency
The main benefit of using ssb IMO is not just pep but also lower noise (3db less) which equates to roughly half the noise level you would receive on eg am.
So even without the benefit of slightly more power, range would still be improved due to better reception.
I think this is especially important now due to the larger distances between stations. Its no accident that the mode of choice for telephony on hf is ssb throughout the world including shipping and the armed forces
Posted: Tue Oct 04, 2011 1:30 pm
by Morat
hmm interesting :)
So, is there a theoretical percentage increase in range? I realise that everything depends on local conditions but if you are achieving 5 miles at the moment, would you be able to predict a 10% increase in workable range? 20%? using SSB?
Posted: Tue Oct 04, 2011 8:57 pm
by Adriano9966
:D you will definately have improved range on ssb even the weakest of signals are still intelligible I dont think it would be possible to give an exact percentage of improvement over eg AM because there are so many variables to consider eg topography,atmospheric noise, local interference .Once we get it you will soon realise the benefits 8)
Posted: Wed Oct 05, 2011 1:31 pm
by needle bender
Hi morat,,ssb most certainly has a consideral range advantage over am/fm modes of operation...you would be better off to google am/fm/ssb modes of operation to gain a better understanding...the only downside to ssb is fidelity of recieved audio...if you can call it a downside...you need to develop ssb ears...but you do eventually attune to it...but its all good that we are to have multimode cb at long last... :D
Posted: Fri Oct 07, 2011 9:24 am
by Morat
I have to admit I've done some googling but I haven't quite grasped it yet. I used to use the Clansman radios so I know what sort of noise they make - if it's similar then it shouldn't be a problem.
Posted: Fri Oct 07, 2011 11:55 am
by needle bender
Hi morat,,dont know much about the clansman radios,,so i googled them...seems to be a few models...one i looked at was the prc 320 and can be purchased for £425...covers 2-30 mhz,100hz channel spacing gives 280,000 channels. and at 30 watts pep into a whip antenna under normal conditions has a range in excess of 40 km...thats on a par with ssb cb radio...and of course with a good vertical antenna anything is possible...yeah tiz an interesting tranceiver ....would like one myself :D
Posted: Fri Oct 07, 2011 4:15 pm
by Morat
Great if you want to talk to the TA! I don't think the regular army has them any more.
