Making a battery pack
radiomaker
I am going to make up a re-chargeable battery pack out of the original pack that came with my Eurosonic Ultimate.
The problem is that the Li-ion cells are marked 3.7V.
I don't know much about these batteries & how they behave. Surely if I put 12V in from a wall-wart then I get 12V out, no problem?
dont forget about the ampage as well
radiomaker
I found the Li-ion cells I was looking at would not fit the Eurosonic battery pack, because they were not 'AA' size.
I figure that i'd need a slide-on adapter to put 12V directly into the radio.
I have tried a off-the-shelf battery pack & I am having issues with that as well!
S*** happens 4 sure!
The Eurosonic Ultimate is fine.
Your contributions are welcomed on the matter of the off-the-shelf battery pack in a separate topic to this.
