...and for my next (ignorant) antenna Q...
Posted: Sat Oct 15, 2011 5:51 pm
by AdvancedRoadcraft
...OK, the mobile CB antenna is up, fixed & working great.
But I now want to run a separate scanner (to be used for CB channels only) in the car. Can I just use a "splitter" at the CB end of the antenna cable and run a short length from the "splitter" to each of the two units, or would I be better off installing a dedicated antenna specially for the scanner?
And, if the latter, any recommendations would be gratefully received.
Thanks in advance, chaps, B
Re: ...and for my next (ignorant) antenna Q...
Posted: Sat Oct 15, 2011 6:48 pm
by needle bender
Hi,you say you want a scanner just to monitor cb channels???...well why not use a cb transceiver with scan capability...or are you looking to scan a more comprehensive range of cb frequencies...freeband etc???
Posted: Sat Oct 15, 2011 9:52 pm
by Andy Nazel
Hello!
If you just use a "splitter" then the 4watts from your cb will go straight into your scanners aerial hole when you key up and kill its recieve circuit!!
Best to use a separate aerial.Check out Thunderpoles range to see which one is best for you but I've used a Skyscan Mobile and had no problems the only thing is the" multi- antannae" arrangement does draw attention.Was once asked"Are you TV Licensing"
Posted: Sat Oct 15, 2011 10:26 pm
needle bender wrote:Hi,you say you want a scanner just to monitor cb channels???...well why not use a cb transceiver with scan capability...or are you looking to scan a more comprehensive range of cb frequencies...freeband etc???
Because I've got a (non-scanning) CB unit that I'm happy with and don't therefore want to swap just to get one extra feature!
Best, B
Posted: Sat Oct 15, 2011 10:28 pm
Andy Nazel wrote:Hello!
That was a circuit description that even I could understand!
Many thanks for saving me an expensive mistake; I'll do as you suggest.
Best, B
Posted: Sun Oct 16, 2011 8:10 pm
