Basic advice needed
Posted: Mon Oct 17, 2011 5:43 pm
by JohnOF
I am making this enquiry on behalf of an elderly lady.
She wishes to receive Church ceremony CB broadcasts which are transmitted from two local churches on a around channel 10 - 30 (as far as I have been told). She was loaned that 'normal' receiver - a (other company) - but the reception was very poor.
I will buy her a better receiver which can be hand-held or a small table top unit. In the extreme, I suppose it would be possible to fix an external aerial as long as the receiver has a socket for this.
Any suggestions?
Thanks.
Re: Basic advice needed
Posted: Tue Oct 18, 2011 7:48 am
if you see her regulaly then a hand held would do but would be easier for her to use std cb powered by a power pack and external antenna or a long piece of wire as she is not txing on it
the hand held woul need batteries or a power supply and the controls are fiddly if she has arthritis or such
Posted: Wed Oct 19, 2011 4:56 pm
by Guzzy
Does the "'normal' receiver - a (other company)", have a metal telescopic whip?
If it does, try adding at least 9ft of wire to the end of it. Try stringing the wire vertically.
You will have probably noticed that most CB'ers have large vertical antennas mounted up outside on the roof of their houses. This isn't a fashion statement. :wink:
