Midland 77-805 Port-A Pak
radiomaker
Does anyone know the precise spec of the plug needed for the DC input socket?
I just got a Port-A-Pak & predictably it is the battery pack that needs some remedial attention.
The contacts are corroded in places and even the wires of the battery leads are corroded!
Dunno if I can re-claim it, but I have another 10X 'AA' cell holder, so I ain't too worried. I was also going to make a lead to put on my motorbike battery and fix the car cig lighter adapter that came with the rig.
BTW: The rig is fine on a AC adapter. Nobody on 19 at this time of day though.
positive center on plug and they where a cracking set i had the royce which midland copied fully versitile and worked well
radiomaker
I thought that if someone could come up with the right inner & outer diameter for the plug I would not have to try several before I found one that was a good fit.
cant make it too easy
