Oh, no...another "What scanner should I buy?" question. (So
Posted: Fri Nov 11, 2011 5:47 pm
by AdvancedRoadcraft
But my needs are very specific, so please help:
-only needs to scan UK & Euro CB frequencies - anything over that is a plus, but not required.
-be really nice if when scanning CB it showed Channel Numbers, not just freq's
-must work on a 12v DC input (from the car socket) or work well with rechargeables that can be recharged in situ.
-readily available second hand or cheap if new recommended.
What does the Thunderpole Massive advise>
Best (& thanks in advance) B
Re: Oh, no...another "What scanner should I buy?" question.
Posted: Fri Nov 11, 2011 7:20 pm
by Guzzy
Whatever you buy, you will need a CB antenna mounted outside the vehicle to actually successfully receive the CB transmissions.
So why not buy a CB radio? :D
Pick one with a scan function and away you go. :wink:
If you need to scan the UK and EU (CEPT) channels, make sure you buy a 'multi-standard' model.
How about these as two (new) suggestions:
http://www.thunderpole.co.uk/intek-m-799-plus.html
http://www.thunderpole.co.uk/midland_42_plus.htm
Posted: Sun Nov 13, 2011 1:37 am
You are probably right...just an inbuilt reluctance I guess to "start all over again" with a new set. (Already got a CB & antenna.)
But, hey ho, it won't be the first time I went a looong way down the wrong road before fessing up and doing a U-turn.
I'll let you know what I end up doing and will certainly check out your suggestions.
Thanks, again, B
