Advise on SWR
UGE
Hi guys, just started to fit my new rig over the weekend and wasnt getting much of a signal (or people was too far away) and i had got the SWR set at 1.3
so i popped on here to have a look for advise on the SWR.
I read about seeing what the SWR was on CH1 and CH40 so went out to check.
On CH1 i am gettin a SWR of 1.4-1.5 and on CH40 im getting 1.1 is this rite or do i need to do some more tuning?
Im running a CB with a SS Orbitor mounted on the winchbumper of my Pajero
any advise/tips would be very greatfull
no that will be absolutely fine
UGE
thanx for that.
any idea why i couldnt hear someone just over a mile away?
could i have a groundplain problem?
Offplanet
Sounds like the antenna is too low down - higher the better on the vehicle (ideally in the centre of the roof to give a more even performance pattern)
yes get it up top gutter mount or mag
UGE
hmmmmmm gutter or mag on roof could be a problem,
I have a aluminium roof crate, it is earthed to the car as i had to use it as an earth for my extra reversing/work lights.
Would that be a problem?
Also hight could be an issue, i cant get into many carparks at the moment due to the car + lifts and roof crate making 230cm my min clearence
currently the tip of the antenna is at 267cm from the ground, if i was to mount it on the crate it would be 377cm from the ground to the tip.
I do go laning and want to go off road with the local 4x4 club. What could i do?
at about the same hight as it is at the moment on my old car i could get about 10-15mils and that was with a cheep springer (orbiter rep) from maplins.
any ideas?
there are various mounts at our sponsors that will do the job but some pics might help us on here to sort you out
A Tankwhip would be better for static transmittions but were you mount the antenna will shape your ground plane drasticly , a Antenna mounted on the front bumper will give most of its groundplane ( transmittion range ) towards the rear of the vehicle .
Antennas are best mounted central on a vehicle for uniform groundplane but if you dont want to drill the roof then u could mount a springer on the front and rear bumper using a purpose built 75 ohm twin splitter cable.
Co phase harness http://www.thunderpole.co.uk/patchleads.htm
