mother in law! 10-4!
Posted: Wed Mar 07, 2012 11:04 pm
by dc4
my mum in law lives on the other side of basingstoke and im in guildford.that is about 40 miles away? anyhow, my current ambition is to be able to set myself and her up a radio system where she can call us and hear us if neccessary. obviously these will be two homebases but what equipment could do this on the 27fm without going too over the top price wise? cheers doug!
Re: mother in law! 10-4!
Posted: Thu Mar 08, 2012 9:26 am
by needle bender
Hi,guildford,Basingstoke,about 40 miles you say..well,radio waves travel as the crows flies so you could knock a few miles off that....much depends on the lay of the land between you and your mother in law,,are you both on high ground or in the middle of housing estates etc...can you get your antennas way up high...yeah in theory it could be done...but i would be inclined to say to you that really its wishful thinking..if you yourself are into radio set up your own station first and see what kind of range you can achieve...but if its just a case of keeping in touch with mother in law only,maybe skype is your answer...
Posted: Sun Mar 11, 2012 8:38 pm
by Adriano9966
I think its possible but not without problems. I have looked at the satellite images and it seems to be mainly level ground between both points apart from Aldershot.
a simple 1/2 or 5/8 wave vertical antenna should be sufficient fed by reasonably good cable eg RG213 or RG8 (there are better ones which are a bit more expensive but with lower loss)
Mount this as high as possible in both installations .....the antenna is make or break for any radio installation so the more time and effort you spend on this the better the station
the type of cb transceiver used is relative as the antenna is the most important element
Its most likely that you will get this sort of range at night and if we are talking about 30 miles or so as the crow flies that is achievable in my modest opinion but not all the time
I hope that helps
Posted: Wed Mar 14, 2012 2:41 pm
by dc4
thanks for the info chaps! as you say needle bender i will set my home station up first and work it from there, still having a few technicalities with my mobile set up but should have that sorted soon. next thing i suppose is getting the right antenna to do the job, is an amtron 99 as good as people say or is there just as good alternatives that would do the same job?
edit: just seen the antenna thread! tut!
Posted: Thu Mar 15, 2012 7:43 am
Posted: Fri Mar 16, 2012 1:39 pm
by dc4
i had a look at that aerial last night on here and its not pricey at all i dont think. and having a fella say that its as good if not better than a 99 makes me think its a wise choice come pay day! going off on a tangent now, does low cloud affect radio signals? i tried out my tank whip last night at newlands corner standard 4watt harrier cbx and didnt hear an awful lot at all whereas the night before i tried it briefly spoke to brighton clearly outside my house, and it was clear.
Posted: Mon Mar 19, 2012 8:11 am
by Bionic Budgie
If you can hear thru all the Russian Taxis!
Posted: Mon Mar 19, 2012 12:57 pm
by needle bender
