Saying Hello
Posted: Sat Apr 21, 2012 7:12 am
by davidoff
Hi out there. I am David (handle WHITEHOUSE) and have just taken delivery of a T-1000 from Thunderpole and set it up in my Defender. Have got it on U 19 channel but have heard no voices yet!! :(
I am In Cirencester in the Cotswolds. I will go further afield and see if I can get anyone to talk to today. Cheers.
Re: Saying Hello
Posted: Sat Apr 21, 2012 3:26 pm
by Offplanet
Head up to the hills between 2pm and 4pm on a Sunday and you should hear a good few on the Sunday DX (Ch32 UKFM) - there's also a fair bit of activity on CH24 in Gloucestershire :wink:
Re: Saying Hello
Posted: Sat Apr 21, 2012 6:57 pm
by davidoff
Thank you. I will do that. There seems to be quite a lot of foreign-sounding (Polish?) activity on Ch 20, as I found out this morning. Also local taxis on another channel (which I can't remember). A bit more on 19 in the Stroud area (lorry drivers, I think). Cheers for now.
Re: Saying Hello
Posted: Sat Apr 21, 2012 8:40 pm
by porky.69
welcome david, like gary says have a drive upto some high ground
Re: Saying Hello
Posted: Sun Apr 22, 2012 10:06 am
hi and welcome
Re: Saying Hello
Posted: Tue May 15, 2012 9:18 am
by needle bender
Hi there,the truly good days of cb radio are long past,,but there are enough users around to make it viable still,,,one of the problems,and its been said many times before are that folks are listening in,,hearing nothing and switching off!!!...cb radio is about two way comms and not listening!!...we need to get back to using a calling channel...in the early days it was channel 14 uk fm...and 19 for mobiles...lets get back to basics..and start calling each other...mids/eu has adopted channel 31as a call channel...hopefully,am/ssb will be introduced later this year and this in itself will give cb radio a new lease of life....in the meantime 1-4 for a copy :D :D :D
Re: Saying Hello
Posted: Tue May 22, 2012 7:00 am
by davidoff
Thanks needlebender that is a very sound (!) comment. I was mooching about on Sunday in my Defender and tuned into Channel 32 (Sunday DX see post from offplanet) and spoke to a guy at the trig point on Malvern Hills (about 30 miles) and could clearly hear but not speak to another guy on the Berkshire Downs. Both these stations must have been static and have had tall aerials.
Re: Saying Hello
Posted: Tue May 22, 2012 11:44 am
by needle bender
Hi davidoff,glad you had a bit of success...with 27 mhz the bigger the antenna the better when it comes to distance...try using a 9 foot tank whip when parked up...they are cheap and work very well!!...(dont try driving about with it though)...from my dx spot here at carn brea i get very good results with the tank whip,but hight is an important factor as well...make use of the eu/mids as well, channel 31...try channel 19 eu/mids on am mode for irish truckers!...but select the spanish setting to get the 4 watts..but bear in mind am mode is illegal at the moment...still waiting on the ofcom clowns to give the ok with am/ssb use...so find that good dx spot and call for those copies.....with me its channel 19 am mode eu/mids...or 27.555 usb...so called freeband... :D
