harrier cb-x mic or equivalent ?
Posted: Wed Jul 11, 2012 7:47 pm
by slimfb
any idea how to get a replacement mic for my harrier cb-x, do i need a harrier mic or can i get something else, thanks in advance
Re: harrier cb-x mic or equivalent ?
Posted: Thu Jul 12, 2012 11:53 am
any mic can be wired for it dont think you will get an original mic as they where only made it the early 80's
Posted: Thu Jul 12, 2012 6:04 pm
by slimfb
thanks for that but .......... how ?
my cb-x seems to be functioning fine, i can receive ok, swr ok, but when i transmit, the other person can hear the mic 'click' , my power meter goes over ok , but he can't hear my voice
i think it's the 'big round thing' inside the mic that's given up the ghost.........it's got a vibration membrane & a sealed metal round unit......i'm not a techy !
so.....will any 4 pin mic work, if not, what do i need to do ? thanks again in advance for help the noobs out there #-o
Posted: Thu Jul 12, 2012 6:06 pm
by killer cam
Give thunderpole a ring they can probably make one up with the correct wiring for you, wiring differs on radios
Posted: Thu Jul 12, 2012 6:31 pm
by slimfb
nice one....thank you
Posted: Mon Jul 16, 2012 6:44 pm
by slimfb
mic came super quick on saturday, tried it in my truck today........same prob..... :(
quess i need a new radio
i know the antenna is important, but as i drive an 8 wheel tipper, i do a bit of quarry & off roading........low trees & stuff getting in the way. does this mean i have to have a springer on top to take the punishiment or is there another way to do it to have the best antenna setup possible ?
is a springer a springer, do they vary in quality & power ?
i better do a post on the antenna forum as well
Posted: Mon Jul 16, 2012 8:59 pm
by porky.69
i dont think much of the springer antennas, thunderpole sell alot of very good mobile antennas, i like the look of the red thunder (bullwhip type) antenna with a red base :wink: *King*
Posted: Tue Jul 17, 2012 9:02 am
send the harrier to andy he will sort you out the harrier is a lot better set than most modern ones so it will not be money wasted
Posted: Tue Jul 17, 2012 3:43 pm
by Dragonfly
The PTBM134AOX board is used in quite a few radios , There is a Mic Volume adjuster inside which may have become faulty, try adjusting it , i have it here in my old 80s scribble pad as Mike gain .
Posted: Tue Jul 17, 2012 6:17 pm
by porky.69
stampman wrote:send the harrier to andy he will sort you out the harrier is a lot better set than most modern ones so it will not be money wasted
very true you cant beat the old radios *King*
Posted: Tue Jul 17, 2012 8:17 pm
by slimfb
thanks, i may well just do that..........i do like the harrier *lurve*
