New tractor, new setup advice
Posted: Fri Oct 12, 2012 8:04 pm
by stewartyboy01824
Hi folks, just had my new tractor, need some aerial advice. Putting in a Lafayette trucker in the din slot next to the stereo. Looks smart! Good cb? Now the aerial; with it being a plastic cab roof, if I cut a piece of steel the same diameter as a mag mount, glue it to the centre of the roof and earth it to a roof bolt with some cable. Is this a good enough base to put a mag mount aerial in terms of ground plane, diffectional pattern and earthing?? Trying to get the best possible setup, want to stay away from mirror mounts!! Any advice greatly appreciated!! Stewartyboy.
Re: New tractor, new setup advice
Posted: Sat Oct 13, 2012 5:17 pm
mirror mounts are the best forthe tractor but you can try earthing the mount and see what happens best of luck
Posted: Sat Oct 13, 2012 7:59 pm
by porky.69
yes enjoy the big wheels :D alot of tractors around here use a magmount type of fixing
Posted: Sat Oct 13, 2012 9:15 pm
by Dragonfly
Or you could try a mag mount on the bonnet if its metal or perhaps a Tank whip on the wheel arch if its metal . I have seen tank whips fixed to the front grill/counter weight .
Fordkid posted some pictures on here of his set up on a Ford tractor .
viewtopic.php?f=24&t=1871&p=9844&hilit=tractor#p9844
More Tractor setups posted here .
Posted: Sun Oct 14, 2012 3:36 pm
by stewartyboy01824
Thanks guys, plastic everything on the tractor these days though, bonnet, roof and wings! Thinking of a roof mount Wilson 1000 now on a home made bracket just below the roof line, folk tell me ther still quite flexible and an amazing antenna. What u Guys think? If I buy a roof mount Wilson will the cabling underneath the bracket be exposed to the elements or not to bad?
Posted: Mon Oct 15, 2012 1:32 pm
just get the wilson mount and you can fit it to a bracket or through the roof you cant go wrong with a wilson
