indoor cb aerial
Posted: Wed Nov 21, 2012 5:16 pm
by gravecad
HI<
What is the best indoor cb aerial to fit a Cobra 19 DX IV EU?
Re: indoor cb aerial
Posted: Thu Nov 22, 2012 12:06 am
by Dragonfly
DV27 sat on a big fridge usually works well .
Posted: Thu Nov 22, 2012 6:19 am
or mount it in the attic on a ground plane
Posted: Fri Jan 18, 2013 5:31 pm
by wildfire
personally i would try the boomerang out easy to set up & can be mounted on to a balcony or on to a pole like the same way you would with a bigger antenna & easy enough to fit in to a loft as it comes with a u-bolt http://www.thunderpole.co.uk/base-cb-an ... erang.html
& i agree the DV27 is a good antenna but will need a big enough tin to mount it on to help the SWR also the tip has a section where you are also able to SWR the DV27 in what ever you pick i hope it all works out for you buddy :D
Posted: Sun Jan 20, 2013 9:22 pm
by Dragonfly
Inverted V Dipole set at 90% is omidirectional
http://www.k7mem.com/Electronic_Noteboo ... d_vee.html
Posted: Mon Nov 04, 2013 6:40 pm
by anraj761
I agree that the DV27 is a good antenna, yet it need a big enough tin to mount right.
Posted: Tue Nov 05, 2013 9:34 am
you can always add to the tin if its not big enough by adding wire leads
Posted: Sat Jan 06, 2024 8:55 pm
by Thunderbolt
Youd be better using a wire antenna outside...or look up people putting wires in housend drain pipes...the saying is...its better to have an untuned antenna outside than it is to have a tuned antenna inside...that speaks volumes about how inside masks the signal...but please dont transmit on an untuned antenna...i did ok as a kid with a dv 27 on a sheet of metal in my bedroom...then a dipole half in the bedroom and half in the loft...my stepdad put a hole in the ceiling of my bedroom in the corner putting the transmitting part in the loft 😃😃😃 gl kev
