What are they saying?
Posted: Sun Feb 17, 2013 12:48 pm
by sputnik
Hi Guys,
Is it me or my CB? I find it almost impossible to understand what some/most breakers are saying, there's only a few who come through clear, most every one else sounds so muffled/distorted I haven't a clue what they're talking about?
I've tried an extension speaker but nothing changed, I've detuned with the Delta Tune, turned down the RF Gain, nothing seems to tune 'em in so I can understand them. I know some are close but every one else seems to be able to answer and hold conversations with these distorted breakers.
I read online it could partly be down to my antenna? it's SWR'd to 1.3, it's a Sirio 5/8 silver rod type thing with a coil and 4 ground planes. do have a join in the coax, when I used a coupler the SWR is 2, I now have a TVI filter in line instead and the SWR is back to 1.3 - anyways, any-body got any ideas or advice?
Thanks,
Sputnik :-)
Re: What are they saying?
Posted: Sun Feb 17, 2013 6:35 pm
by Dragonfly
Post a little vidio of this problem , It may be that you are getting a lot of bleedover from someone near to you , Though this would be unusuall with modern radios these days .Also if two stationa are transmitting at the same time the signal that you hear will be just a mess of noise .
The fact that you are getting different readings with your SWR when you splice in a TVI filter suggests that you are getting a common mode problem , Show us a picture of your Antenna mounting .
Posted: Sun Feb 17, 2013 9:25 pm
by sputnik
Thanks for the reply Dragonfly :-)
I didn't know you could post video and pics on here... I use photobucket to post pics on UKCampsite.co.uk, guess that'll be the same here? will do that soon then.
As a heads up, my twig is clamped to the top of my washing line post, I've earthed the clamps to ground, the reason I did this is because there was an ammount of noise in the modulation of users, SWR is the same with or without the earthing, now, it's either the earthing or the TVI filter that has massivly reduced noise in the broadcast signals and breakers with a good mic are crystal clear! even the ones I can't understand are clean as such.
I don't think it's a cross modulation problem or bleed over, I had a rig in 79 to 81 when every other house had a silver rod lol, it's deffo either the others transmitting off frequency or whatever, or my rig? - as an example, say there are 12 breakers on most of the time, 3 I can hear like they were in the same room, the others, well I can't make out a word they are saying? and they're not always the closest or loudest yet every one else seems to talk to these over modulators no problem?
I'm using a Cobra 29 LX EU straight out of the box - if I change the Country setting to another Euoropean country, I can hear Americans far better than any one local on most occasions, one guy from Phoenix was pushing me about 7lbs without a single crackle in the modulation today, even those who push about 2 or 3 lbs are clear, anyways, that's onother story lol
I will be back armed with a mounting pic or vid and another vid of what I hear very soon.
Cheers :-)
Posted: Mon Feb 18, 2013 12:49 pm
Hi Sputnik,
You can embed photos on here no problem, I use photobucket too and it works fine.
It might be more difficult to post a video directly on here, so it is probably easier to upload to Youtube, Vimeo, or whatever and then post a link to it on here...
Posted: Mon Feb 18, 2013 7:54 pm
by sputnik
Cheers Andy for that snippet of info :-)
I haven't taken a pic as yet as It's dark when I go to work and dark when I come home, I have a day off on Wed so might do it then?..
Just a quick question regarding recieve frequency on this rig, if I have the Delta Tune hard over to the right, I can hear more breakers alot/abit clearer than when it's set in the middle position? is it possible I'm off frequency a nudge on incoming signals? If I am, what can be done about it? I get out radio 5 apparently so the transmit bit works ok.
Sputnik :-)
Posted: Tue Feb 19, 2013 10:17 am
Is it ALL breakers that become clearer when the delta tune is hard over to the right? As if it is just one or two it is more likely that their transmit frequency be slightly off.
Posted: Tue Feb 19, 2013 3:10 pm
by 26-TM-037
Not using those stupid echo mics are they? They seem to make people sound unintelligible.
Posted: Wed Feb 20, 2013 4:13 pm
by sputnik
Pic requested by Dragonfly re antenna mounting.
Hi Guys... first attempt at photo upload, hope I picked the right whatsit? lol
Anyways, I think I've come to a conclusion, there must be a bloke discuised at a rig doctor of a weekend, he must be selling repaired rigs, all his customers can talk to eachother as they must all be off frequency with his 10 bob frequency counter? lol
I can hear quite a few breakers better Delta Tuned hard right but some others who come through ok on normal 12 noon setting do go off frequency a bit, seems I can't win lol.
I will try to post the pic on the other web link setting off photobucket if this doesn't load... :-)
Posted: Fri Feb 22, 2013 4:23 pm
by wildfire
hi sputnik
For normal operation, set the delta tune control to the center position.
This feature has several uses and can help receiver operation.
If a received signal is slightly off frequency, the Delta-Tune control can be used to òfine-tuneó your receiver. Fine tuning is accomplished by listening for a more readable signal at the speaker or by noting the Smeter reading when the Delta-Tune control is operated. Another use of this control is eliminating adjacent interference (bleed over from other channels). If an exceptionally high level signal from an adjacent channel is creating interference on the channel being used, the Delta-Tune can be used to minimize or eliminate the interference. Rotate the control until you obtain minimum adjacent channel interference. NOTE: Delta-Tune is operable only in the receive mode.
another way to explain the delta tune control is that is works the same way as a clarifier does when people sound to be off frequency no matter if your on fm or ssb ect you have to keep turning the control till you both are on the same frequency but most people of fm who are on fm muppet band should already be on the right frequency
Posted: Mon Feb 25, 2013 1:30 am
by sputnik
Thanks for that info wildfire, seems the worst offender, modulation wise has a new rig, not only has he now got a roger bleep but I can make out some of what he's saying - before I installed an inline TVI filter from the 80's, every one pushed me in to the strawberry patch, now they are segrigated quite a lot, one guy who pushed 30+ now pushes 7lb, I like it better like this and the added bonus is, there's a wally with a burner in Grimsby not only does he do a Mr Blobby sound all day, he pushes every one 30+ here in Hull and it's not worth going on, he now pushes me 4lb and I can squelch him out... job's a good un!
I bought a firestick from this site, SWR is off the scale but that's another post in a different section lol - as to the origional question as to why I can't understand what's being said, I have noticed massive differences in clarity, very very few come through clear as a bell and loud, some come through with the crackle louder then they are and they push good numbers, the rest... who knows what they are saying? I wonder if it's because my twig is only 6 feet off the ground? the ground planes might be reacting with the ground in a capacitance kinda way and stuffing reception up? maybe I should tie fishing line to the ends and pull them up banana wise? does any one know what the coil does on this twig? is that where it radiates from?
Sputnik :-)
Posted: Mon Feb 25, 2013 8:17 am
all makes of rigs sound differant plus people put echo chambers on them as well when i first started in 19?????????????
my ring was on the bench more than it was in the car till i thought sod it im going nurotic an it has not been out of the for the last 15 years and the quality control off some off the manufactures leaves a hell of a lot to be desired
Posted: Sat Mar 23, 2013 2:02 pm
by sputnik
UPDATE:-
Well thanks to a breaker called Andy in Hull who has the same rig, I almost solved 80% of my receive problem with 2 clicks and a twizzle!...
Turns out - I set it up wrong right from day 1! (Tut's) I had the "ST" activated cos the book said it would be a clearer reception. Twaddle! lol
When my new mate Andy advised me to turn it off :-) My god! I coud hear conversation from people I couldn't possibly understand just 2 mins before, it was like putting new battries in a hearing aid - suddenly I could join in! lol
Anyways, Andy, if ur ever on Wingfield Rd, Swanfield end, there's a cuppa on the go in the house with a silver Astra van outside :-)
