tipper truck drivers
slimfb
hi all
any of you guys out there with a recommended set up ?
big steel body on a 24 v merc
TTI TCB-900 is DIM Mount size 12 or 24v scan function and front speaker http://www.thunderpole.co.uk/mobile-cbs ... b-900.html
Team Roadcom-FS is din mount 12 or 24v front speaker and has scan and dual watch and VOX http://www.thunderpole.co.uk/mobile-cbs ... om-fs.html
Team Roadcom-FS http://www.youtube.com/watch?v=KLcOMZ2Ck_0
USE the intek a lot better set wired to the 12volt supply in the wagon with an orbiter on a gutter mount at rear
works very well fitted quite a few this way
somersetboy
I've a Harry in the 54 FM12 twig is a big stinger mag mounted to the roof and swr'd in sensible and I've had no issues. Gets out better than anyone else in our yard.
AppleTree
CB Handle: Uncle Bulgaria
somersetboy wrote:I've a Harry in the 54 FM12 twig is a big stinger mag mounted to the roof and swr'd in sensible and I've had no issues. Gets out better than anyone else in our yard.
Most of our trucks have this set up, my blade has a similar set up too...
You Can Find Me On Channel 19 Usually.
Or 145.500 FM 8-)
My YouTube Channel RustySkull Productions
