complete newbie.
lyron
CB Handle: disco 1
my names ron and herladyship is lynda, hence the user name.having no experience what so ever about c b radios i will be lookin for advice. ie what type should i go for etc., we own two landrover disoverys .
no.1 is blossom, a 300tdi 50th anniversary limited edition.
no,2 is lizzy, a very early 3o0 tdi auto.
anyway, looking forward to navigating my way through the forum. 8-[
ron.
ron & lynda'
two disco 1s and an elldiss odessy 4 berth tin tent
mburton2
Im a newbie myself....But I will offer one small bit of info.
I mounted a LCD screen'd Radio in my 300tdi (Off-roader) up high (Out of potential water), by the sun-visor, but because of the viewing angle, Its hard to see what channel Im on.
I put an LED screen'd Radio in my TD5 Disco (Near the gear-shift) as this is my "Road" car (Despite being fitted with a Snorkle) as the chance's of wadeing this in deep water is TINY....but I can still see the channel-display, despite being at an odd angle.
mburton2
lyron
CB Handle: disco 1
many thanks for the very quick reply. advice taken on board.
ron.
ron & lynda'
welcome ron :D
hi and welcome go for a maxon cm10 or a kpo k500 which is shorter in the body so easier to fit use a guttermont if possible with a omega 27 antenn which will tune to both bands ie uk and Europe if you want top performance the spend the money on a top range antenna which will cost you more than the set
hope this points the way slightly and gives you some thoughts
