What is going on?
Posted: Sat Mar 30, 2013 10:13 pm
by CBShed
Hi everyone i`m a newbie and need some help I have a (other company) Minor 40 Channel UK CB Radio I have been fannying around for to long now and don`t get a peep out of no one . I know it`s not the best CB around but for starting out was thinking it was ok but I don`t even get a fart out of it . Is this because no one around me has one ? It has been in my house no responce and its been in my man cave at the bottom of my garden but nothing help please It has a two foot antenna.
Re: What is going on?
Posted: Sun Mar 31, 2013 2:37 pm
by porky.69
i think the antenna is the problem. for homebase use you need a bigger antenna :)
Posted: Sun Mar 31, 2013 6:01 pm
by CBShed
I have a (other company) Mini mag CB antenna because that was advised by a numpty obversely. I even went as far as mounting onto a 4 meter pole still no joy. I was thinking a (other company) L30 LINEAR AMPLIFIER will this also help?.
Posted: Sun Mar 31, 2013 8:21 pm
in a word NO make sure you are on the right freqancy and mode check the swr or buy a better antenna from our suppler
ang get lots of good advice when you ring to order
Posted: Fri Mar 28, 2014 4:34 pm
by marsbar
CBShed wrote:I have a (other company) Mini mag CB antenna because that was advised by a numpty obversely. I even went as far as mounting onto a 4 meter pole still no joy. I was thinking a (other company) L30 LINEAR AMPLIFIER will this also help?.
Is the pole you have mounted it on grounded.
A linear amplifier will not help as you still need to hear incoming not just boost you out going.
make sure that the SWR is right.
if all is still not working for you try to find some one local you to help you most Ham's will help you just ask.
