Groundplane question
Posted: Sun Sep 15, 2013 12:01 pm
by cmickey123
I am wondering if i mount an antenna onto the bracket of the spotlight on the tractor will the earth be good enough?
The bracket is steel and is bolted to the frame of the cab.
If you can help please do,
Re: Groundplane question
Posted: Sun Sep 15, 2013 7:51 pm
by Dragonfly
Sounds good to me , Try a continuity test from that bracket to the chassis to see if the cab is earthed well .
Posted: Sun Sep 15, 2013 8:58 pm
by cmickey123
I'll take your word for it,
Posted: Mon Sep 16, 2013 7:52 am
yes that will work fine always remember to check with the swr meter
Posted: Mon Sep 16, 2013 4:41 pm
by cmickey123
Do i have to check with the swr meter if its a mini orbitor thats pre tuned?
Posted: Mon Sep 16, 2013 4:49 pm
any antenna needs checking as they are designed with a perfect ground plane and most vehicles are not a perfect ground plane so it is always worth checking the first time you fit an antenna
Posted: Mon Sep 16, 2013 5:57 pm
by cmickey123
thats grand,
