Cobra 29 LX EU RX distortion fault
Posted: Tue Nov 12, 2013 2:41 pm
by CaseTrax720b
Something wrong here! 2 x 29LX EU Cb's. No1 was original purchase (T/Pole) -- Rx fault of distorted RX modulation. Returned and replaced with No 2 which has the same fault!! It seems that RX is influenced by the mic used by the CB'r at the "other end". An improvement is noticed when the incoming conversation is via a standard mic. But when a power mic is used the distortion is very bad about 75%. Struggle to carry on the conversation. Nobody I talk to uses a standard mic!!! Hence the problem. Because warranties are not transferable I can't purchase from original owner. But hope to do so with your help. An otherwise a 1st class rig getting good reports. Hope someone can help. Thanks Casetrax720b
Re: Cobra 29 LX EU RX distortion fault
Posted: Wed Nov 13, 2013 5:46 pm
by Andy Nazel
Hi Casetrax.....have you tried turning off the SoundTracker feature? I found it helped with mine and its only any good if talking to another Cobra radio on a standard mic.Hope this helps,as you say a nice radio otherwise.
Posted: Wed Nov 13, 2013 9:57 pm
by Dragonfly
It sounds like the front end of the radio is very sensitive , Have you tried turning the RF gain dial half way down to attenuate the incoming signal , It may help to stop the distortion you are hearing from the speaker .I have an old Harrier that overloads from close Hi gain signals so its not a new problem .
Posted: Thu Nov 14, 2013 7:53 am
Posted: Thu Nov 14, 2013 8:29 pm
by CaseTrax720b
Thanks for your suggestions ref. the distortion fault. Andy N - sound tracker Off but no difference. Stampman - problem RX only. The rig is first class otherwise. Very good reports from all contacts. Dragonfly - Think you are the nearest with your idea of over sensitive receive side. Being a "technical dinosaur" I have tried all the obvious things. Is it a problem to reduce the sensitivity? Whatever needs to be done the rig will have to go back to the owner and be sorted out under the warranty. At the end of it all I should end up with an excellent CB rig. Hoping for a few more hints for the not so handyman!! I seem to be the only one to have this problem. There must others as I have had two 29s with this issue. Many Thanks and keep up the good work Casetrax
