PRESIDENT GRANT II mod
Posted: Wed Apr 09, 2014 3:01 pm
I have seen a lot about the mod to put the PRESIDENT GRANT II in to export mode.
My question is if you were to move the jumper back and rejoin the wire would it be back as it was?
If so why can you not put a switch in line so you can change from one mod to the other,
the reason for doing this is in export mod it will not go to lets say ch 19 27,781.5mhz
