Interference
Posted: Tue Jul 01, 2014 7:56 pm
by Darren226
Hi having an issue with interference the rig is a tti 1100 it's ok on receive AM/FM and ok on transmit FM but on transmit AM all it transmits is noise the swr is 1:1 I've tried connecting to 4 different power sources and two different voltage droppers in my truck all to no avail ideas any one?
Re: Interference
Posted: Tue Jul 01, 2014 9:24 pm
by Dragonfly
Multinorm radios will only allow AM to work on the german and polish bands , The TTI TCB1100 can be opened up to 25 to 30mhz AM FM by moving a resistor inside , The UK40 wont be there though in export mode so the radio will have to be switched off and restarted with a particular button pressed to switch between UK norms and Export mode each time you want to use AM on mid band .
Here is the mod for moving the resistor to enable Export Mode .
http://uk1ab.comlu.com/ukmods/ukmod002.html
Re: Interference
Posted: Wed Jul 02, 2014 7:38 am
Re: Interference
Posted: Wed Jul 02, 2014 9:26 am
by Dragonfly
Just checked on my multinorm handheld and AM FM works on the Italian band ,Learn something new every day , cheers Stampman
Re: Interference
Posted: Wed Jul 02, 2014 11:21 am
by Darren226
Am works on whatever country code you choose except UK obviously,(although I suppose that will now change on new ones seeing as the law has changed) can receive but not transmit after a couple of phone calls in which both said same thing sounds like dry joint on the am transmitter circuit. Thanks for your help though guys.
