best antenna for superstar 6900n
Posted: Thu Aug 07, 2014 5:15 pm
by dantek
Thinking of getting a superstar s6900n 10/11m band
Which mobile antenna will be best to cover 10m and 11m?
Will a regular CB mobile antenna do?
I currently have a mini stinger
Re: best antenna for superstar 6900n
Posted: Fri Aug 08, 2014 7:53 am
to use on the 10 meter band you need to take your foundation licence as it is only used by radio hams i use the wilson 1000 antenna and have done since 1982 so was well worth buying and does perform well
Posted: Fri Aug 15, 2014 6:34 pm
by Mudslinger
Original Modulator or one of the Big Sirios.
I would avoid springer types because the SWR can change as you drive along due to the coils closing together, but other than that generally speaking the bigger the better.
