Ground Mounted Antenna Questions
Posted: Sun Aug 24, 2014 11:32 am
Hi i am hoping someone can help me out with an idea i have got regarding ground mounting a 1/2 Wave sigma venom vertical. My intention is to ground mount the vertical due to antenna restrictions at my qth, and i am going to run about 80 radials out from the base using a radial plate. Could someone put me right regarding attaching the coax to the antenna and radial plate......do i attach the coax to the SO239 on the base of the antenna and run a cable from the antenna mounting bracket to the radial plate .....or do i open the antenna base and get rid of the coil that is in there and use the SO239 fitting on the radial plate and attach the center wire to the vertical? Would it matter if i just mount the antenna without modifying it...on a pole driven into the ground with the radial plate at the bottom? I measured the resistance on the antenna and it gives a direct short from the inner of the SO239 to the outer due i think to the coil in the bottom. I have seen ground mounted antennas where they insulate the vertical element from the radials and im not sure if my antenna is right for the job in hand or if i can modify in some way??
Hope someone can help as im starting to go grey thinking about it...and cant find any info on the net:-(
Thank You
Doodlebug20
Thank You
Doodlebug20
