Aerial stopping mobile phones and wifi working?
Posted: Sun Aug 24, 2014 3:26 pm
by Mancalleddave
Hi
My name is Dave from South Wales and I just need a bit of advice.
Yesterday I constructed a 20ft 'mast' out of 8 long bamboo poles taped
Together with a homemade wire coax cable dipole on the top. Some old coax went
From the wire antenna I strung a long coax cable to the kitchen
Window to the cb radio set.
I just had my neighbour upstairs, (I live in flats) knock the door asking
Me to remove the antenna because it is stopping calls coming to his mobile
Phone! He says 2 other neighbours say their mobile phones and wifi Internet
Is effected. He showed me his phone and demonstrated it was off.i said
The cb was not even turned on! He said 'yeah but it still receives signal'
Like somehow the antenna is sucking up his signals.
Can this be true or do the neighbours just think its an eyesore. I have a
Legal cb set, no extra power whatsoever.me and my mrs have had no
Problems with wifi or mobile reception.
Can a simple length of coax across a garden cause mobiles and wifi
Signals of neighbours to not work?
I have removed this home brew antenna but I'm not happy as I planned
To fit a thunderpole5 in the future, please advice needed so I know if
I have a leg for standing
Re: Aerial stopping mobile phones and wifi working?
Posted: Sun Aug 24, 2014 8:14 pm
by Andy Nazel
Hi Mancalleddave.Theres's nothing at all in what your neighbour says and you should put your aerial back as soon as possible.As you say it's a legal set up so the law is on your side and if you get more complaints tel them to naff off and here's why,CB frequencies are nowhere near the ones used by wifi and mobiles and will not affect them,it's more likely they will cause your CB interference.So get yourself back on the air safe in the knowledge that your neighbour is an idiot and has no idea what he's talking about.The only thing to bear in mind is planning regs in your area and also if your landlord approves.Hope this helps....Andy.
Posted: Sun Aug 24, 2014 11:00 pm
by Mancalleddave
Thanks andy. Puts my mind to rest. I thought I could detect a hint of manure
Posted: Wed Oct 01, 2014 10:05 pm
by OpticalGhost
I have a sneaky suspicion neighbour does not like big tall aerial outside.
However you described at least 3 peoples phone and wifi being affected, this sounds more like channel collision to me, the solution is to keep the aerial its probably not degrading their service, what the issue might be is neighbour A is on wifi using channel 11 so is neighbour B and C - ask each to use a different channel - if their unsure how to set a router to use a different channel have them call their own ISP's.
Funny we had the same issue 20 years ago with CB lol, 2 convo's on overlapping channel :D well its a broadband issue, as for the mobile phones - check none are using virgin media - again change the channel it could cause a modern smartphone to lose signal both work on the same frequency - virgin can tell them how to switch it off or change it slightly, im not sure but the new virgin boxes might only have 1 5mhz channel with 2.4 having 1-11
