Old CB not wanting to play
Posted: Sat Nov 01, 2014 8:57 pm
by sando63
Hello folks, I have only just dug my old CB out of the loft and actually remembered how much fun they were :D BUT !!
just recently I have been able to receive but not reply :( . Bin told my mike is faulty but can't just replace it with any old 4 pin mike it has to be the same make as the rig ? This must be correct because I tried my mates 4 pin mike and it did not work.....Bugger. Even bigger Bugger is I dont know the make of my rig...Oh eck. Got model numbers on the back, can anyone give me a big shove in the right direction please, Thanks Sando63 :D .
Re: Old CB not wanting to play
Posted: Sun Nov 02, 2014 9:10 am
model numbers would be good as there are about 5 combinations of mike wirings on a 4 pin mike
Posted: Tue Nov 04, 2014 8:12 pm
by sando63
Cheer's stampman, are these any good to ya :lol: Serial No 873237, model DW 900FM, and finally MPT 1320uk, it's all Korean to me :cry: Thanks for your reply.....PS, if you say pin No 3 and 4 need swapping over for example, which pin is which, or which is 3 and which is 4 :D I suppose it's easy when you know how, Regard, Sando63.
Posted: Tue Nov 04, 2014 11:58 pm
by Dragonfly
Think its a KERNOW DW-900FM .
Posted: Wed Nov 05, 2014 12:16 am
by Dragonfly
Dose it look like this - http://www.cbmuseum.nl/Engeland.htm
Post a pic of your mic as midland / Kernow have a variety of mics .
Posted: Wed Nov 05, 2014 12:54 am
by Dragonfly
If it is the Kernow then it will most likely be wired the same as the Kernow 1100 and 5100 unless it has channel change on the mic but it looks 4 pin so so it probably wont have mic channell change ,
Loads of choice on the Thunderpoll shop - http://www.thunderpole.co.uk/cb-microphones.html
Posted: Wed Nov 05, 2014 8:32 am
kernow where standard wired so one that fits the cybernet chassied sutch as rotel or harrier should do the job
