Cb Won't Power up
Hi there, i jumped into my tractor this morning and tried to turn on my cb radio, the radio is a tti tcb 771, the cb wont power up at all, ive checked the connection and theres nothing broken, it was working yesterday when i tried it, does anybody know what might be wrong
, the tractor the cb is hooked upto is a John Deere 7530, thank you!
Is there 12v at the sockets , And is the radios 2amp fuse ok , Check the fuse holder as i have seen the wire pull down into its tunnell causing the fuse not to be ablt to touch its connection . check the ciggy plug incase a wire has come off .
A OHM meter will find the problem .
