Cb Won't Power up
Posted: Sun Nov 16, 2014 6:07 pm
by JamieT
Hi there, i jumped into my tractor this morning and tried to turn on my cb radio, the radio is a tti tcb 771, the cb wont power up at all, ive checked the connection and theres nothing broken, it was working yesterday when i tried it, does anybody know what might be wrong
, the tractor the cb is hooked upto is a John Deere 7530, thank you!
Re: Cb Won't Power up
Posted: Mon Nov 17, 2014 7:51 am
Posted: Mon Nov 17, 2014 8:08 pm
by JamieT
Thanks Stampman, ive got 3 12v sockets in the tractor and ive tried all 3 and none of them work, the cb powers up but connecting the leads to the battery and then to the cb but it wont connect up any where else
Posted: Mon Nov 17, 2014 10:54 pm
by Dragonfly
Is there 12v at the sockets , And is the radios 2amp fuse ok , Check the fuse holder as i have seen the wire pull down into its tunnell causing the fuse not to be ablt to touch its connection . check the ciggy plug incase a wire has come off .
A OHM meter will find the problem .
Posted: Mon Nov 17, 2014 11:31 pm
by JamieT
Had a go tonight and plugged in another electrical device into the socket and it didnt work, a 30 amp fuse has gone which powers the sockets , its nothing major thankfully
