what is wrong
Posted: Tue Nov 25, 2014 4:24 pm
by bruce rae
recently brought a new radio from thunderpole 2 weeks ago due to my living arrangement cant have areial outside or on roof yet so ive got a thunderpole orbitor center loaded coil 1.65mm with a magmount its on a old filing
cabinet which ive turned on its side getting a good swr on ch 1 its 1.2 on 40 its 1.4 but im not reciving very well cant hardly hear people in next town 8 miles away have used this set up before years ago and used to recive and hear breakers a good few miles away used to hear the leicester lads about 20 miles away..the power pack is a 30 amp with 2 needles one for voltage and one for amps the amp needle dosent move so i dont know if its the power supply or the areial
Re: what is wrong
Posted: Tue Nov 25, 2014 7:42 pm
by Dragonfly
A standard CB will only pull 1 amp on TX and half amp on RX so you wont see much needle movement on a 30 amp supply .
The good thing is that you could power a decent burner and preamp with that SWR reading but the receive problem could be due to locale interference from a cheep laptop charger or Xbox
