Help re: transceiver/license etc for van>base communication
Posted: Thu Dec 25, 2014 5:36 pm
by boombox
Hello
I have a van and I would like to be in touch with a static location by radio when I'm out and about. A 3 mile range would be adequate, but it must be true 3 mile. i.e. not PMR446 3 mile! :-)
Can anyone advise what license would be needed for such a setup, and for extra points a basic portable transceiver for the van and a mains powered base station for home?
THANK YOU!
Re: Help re: transceiver/license etc for van>base communicat
Posted: Thu Dec 25, 2014 7:37 pm
by stoner_26
I not a expert by any means but I would say either use CB radio mobile in van and base station at the static site. Or might be worth considering using handheld 4W uhf radios, I have motorola cp040 and they will work over a mile apart with 2 handhelds but will go further dependant on terrain. I would have thought with a uhf base station to handhelp would go a lot further if the base station had a good antenna nice and high.
Hope this can help even a little into some options but there are some really good people on here just can take a while to get a reply sometimes
Posted: Thu Dec 25, 2014 7:56 pm
by hobgobblin
I'd say a CB radio set-up. At the static end you want a decent homebase antenna running to a rig with power supply. Then a rig in the van with a decent mobile antenna. See on the Thunderpole site for all the stuff you need. You'll definitely be better with all that than PMR handhelds. Good luck and keep us posted.
Posted: Thu Dec 25, 2014 8:31 pm
by boombox
Cb sounds good but I'm a bit worried about idiots (and to a much lesser extent eavesdropping) - with CB. Have things changed in the last 15 years since I last used CB?
I was also wondering if a business license might be an alternative?
Thanks!
Posted: Thu Dec 25, 2014 9:09 pm
by stoner_26
Like before I'm no expert but if general chat then CB if anything more private passing over details and such I would go for hand held and base station UHF and buy a licence with your own frequency that way it's more private and no one to interrupt or to talk over you
Posted: Sat Dec 27, 2014 11:21 am
CB CHEAP but can be heard pmr cost quite a lot more and can still be overheard by anyone with a scanner
so basically depends depends how deep you pockets are
Posted: Sat Dec 27, 2014 6:46 pm
by boombox
stampman wrote:CB CHEAP but can be heard pmr cost quite a lot more and can still be overheard by anyone with a scanner
Thanks. Did you mean to say that even licensed "business only" frequencies can be overhead by anyone with a scanner?
Posted: Sat Dec 27, 2014 7:04 pm
by stoner_26
You can go even further and go encrypted digital UHF radios which I think scanners won't (correct if wrong) work but that costs a lot more so all dependant on budget and what your using them for.
