help with mobile cb please
Posted: Sun May 03, 2015 9:14 am
by mackinaw156
hi i have just installed a cb in landrover with antenna on gutter mount and when i press mic reading is swr maximum , i have also conected wire from antenna to battery neg to ground it ,i this ok
i am very confused what to do next and am thinking of buying swr meter ?
please help lol
Re: help with mobile cb please
Posted: Mon May 04, 2015 7:11 am
by mackinaw156
1 day later , 8 views and no replies ?
comon guys have a heart lol
Posted: Tue May 05, 2015 1:01 pm
sorry been distracted by a small problem swr = maxim do you mean its reading in the RED all the way through
Posted: Tue May 05, 2015 7:54 pm
by kester58
you need to SWR always, get one asap, but that doesn't sound like your problem
the aerial needs to make good contact with a "ground plane", think of it as a metal mirror to reflect the waves up & outwards - aluminium body work doesn't do this
the aerial negative/coax shield needs to be "earthed" to negative, which the neg power lead to the radio should achieve, but another wire to a good earth will help.
make sure your extra neg wire is not touching the aerial or centre wire, but just the outer sheath
Posted: Wed May 06, 2015 2:42 pm
no need for wire from base of antenna to neg on battery in fact it complicates it just go basic gutter mount in to roof and then check swr
Posted: Thu Jun 11, 2015 7:10 pm
by kester58
1 month later and no update........did you sort it Mac?
