Intek 520 Plus Power supply
Posted: Sun May 03, 2015 9:51 pm
by hangar18
Hello folks, I'm relatively new to the current cb scene, i was big into it in the 1990's but I've been out of the loop for quite some time, anyway, i just bought the Intek 520 Plus handheld cb radio, it's a great wee radio, but is there no way that i can power the thing from a mains ac/dc power pack? surely it doesn't HAVE to be run from batteries only, does it?
Can i just buy a regular regulated multivolt adaptor and set it to the 12v required and get the right connection on the end to fit the charge socket on the top of the cb? I've never heard of a handheld cb that you can't just run from the mains instead of gutsing batteries up.
Any help would be greatly appreciated.
Best wishes
Rob.
Re: Intek 520 Plus Power supply
Posted: Tue May 05, 2015 1:03 pm
Posted: Tue May 05, 2015 2:43 pm
Hi Rob,
You can run it off 12v but you have to use one of these...
http://www.thunderpole.co.uk/cb-handhel ... r-kit.html
Posted: Tue May 05, 2015 10:07 pm
by hangar18
Hi Andy
Man y thanks for the quick reply, but i don't think i made myself very clear, that lead came with the intek unit and it's really just for running your 520 plus from your car battery, what i want is to run the unit from a multipower adaptor, the kind you get to run radios, games, musical keyboards etc. etc. just a regular multivolt multiprong adaptor, if i plug one of those into the charge socket will it power the handheld or will it perhaps blow the rig?
Thanks again
Rob.
Posted: Wed May 06, 2015 12:50 pm
by Dragonfly
I have a dedicated charger with my 520 plus ,looks like it came from china as it requires an adaptor to fit into the wall .It plugs into the mic socket on the top of the radio and charges whilst in use , iv,e never tried it with the batteries removed so cant say if it would power the radio on its own .
Posted: Wed May 06, 2015 5:05 pm
No it won't run the radio unfortunately, the socket on the side of the radio is only for charging the batteries I'm afraid.
The only way to run the radio from a 12v source is to use the car kit.
You could use this PSU connected to a cigarette lighter socket...
http://www.thunderpole.co.uk/power-supp ... ry-3a.html
Posted: Thu May 07, 2015 5:26 pm
by hangar18
Thanks dragonfly and Andy, that's exactly the info i was looking for, not what i wanted to hear though..
Thanks again.
Rob
Posted: Thu Sep 03, 2015 10:36 pm
by Stickley80
I recently got me a 520 plus, the guy I got it from used the car power adaptor with an external antenna. But he had the rubber duck antenna attached at the same time... On reading the instruction it say remove the rubber duck before a,ttaching to the external... Is this likely to damage the radio??
Posted: Mon Sep 07, 2015 9:35 am
It is a possibility, but in reality you would probably have to be transmitting for a long time through both antennas to damage the radio.
Posted: Mon Sep 14, 2015 11:32 pm
by Stickley80
Ta! Thank you! All working fine
Posted: Tue Sep 15, 2015 9:23 am
Good stuff
