Alan 42 Multi external antenna - SWR?
Posted: Mon Jun 08, 2015 2:07 pm
by BazRDI
Hi all, first post.
I'm a euro trucker with little tech knowledge of CB's, but technically proficient otherwise. This may seem a stupid question, but I genuinely don't know the answer.
I've fitted CB's before, but I'm in a loaner truck, and purchased a handheld Alan 42 multi to use until I have another permanent cab. I would like to connect the handheld to the cab's external aerial. I have the right fittings for connection to the handheld's rubber antenna connector, but will I still need to SWR it?
Many thanks.
Re: Alan 42 Multi external antenna - SWR?
Posted: Mon Jun 08, 2015 3:26 pm
by andy@thunderpole.co.uk
Hi and welcome to the forum.
It is actually the antenna that you are checking the SWR on, so if it is already tuned then no it should be fine. But if you are not sure about the SWR reading of the antenna then it is always worth putting a meter in line to make sure the reading isn't too high, because a very high reading could damage your CB.
