White noise
Posted: Wed Jun 14, 2006 6:17 pm
by fenlander
I am a novice at this cb use, i find the most anoying aspect is the white noise or static sound, i use the squeltch control to minimise this but wish to know what causes this and how to avoid it. I use a (other company) minor with a stinger antena mounted on a gutter mount on my truck. Any helpful suggestions please.
Posted: Thu Jun 15, 2006 10:37 am
by andy@thunderpole.co.uk
It is caused by a number of things, electronic equipment, atmospheric conditions and even static in the air.
Unfortunately there is not much you can do about it, it is a characteristic of FM (frequency modulation) which CB radios use.
However if it is really bad in your truck, i.e. more than 5 pounds on the signal meter constantly then you may have interference coming from inside the cab. It can be caused by any electronic equipment but the most common cause in trucks is 'switch mode droppers'. They create a signal that is picked up by the CB and the only way to stop it is to replace the dropper with a standard one.
The other way to reduce it would be to upgrade your cable, or your radio, as the (other company) is a budget radio and would not be as good as something like a Midland or an Intek.
White noise
Posted: Thu Jun 15, 2006 4:39 pm
by fenlander
andy@thunderpole.co.uk wrote:It is caused by a number of things, electronic equipment, atmospheric conditions and even static in the air.
Hi Andy
Thanks for the info, i will be putting in an order for a midland asap.
white noise
Posted: Sun Sep 03, 2006 8:09 pm
by k8 cowboy
hi fenlander i have same probs with my truck yours wouldnt be swedish would it? tryd everything give up now just turn sqwelch right up until finnished with equipment pain but nobody seems to have answer
Posted: Mon Sep 04, 2006 9:06 am
by Basilsparents
You always have SOME white noise, wherever your radio is. However, excessive white noise (past about halfway on your squelch knob) is usually caused by ignition circuits, sadly. I get it in my golf, a little bit, even though it is rumoured that my vintage doesn't even have an engine XD
Posted: Mon Sep 04, 2006 1:04 pm
interferance in a waggon is a pain to sort first you have to locate the item that is causing it ,best way put the cb on an independant power sorce this prove wether is the dropper or not if dropper is ok the switch on the ignition if the interfferance appears pull each fuse untill it disappears this will give you the circuit it is on then isolate each piece of equipment on the circuit till you find the interferrane get it suppressed and you a happy bunny
cheers and beers
b
Posted: Mon Sep 04, 2006 7:55 pm
by Basilsparents
Just don't get all the fuses mixed up XD Then you'll find that your car won't start, bit like mine
