Using Existing Car Aerial for CB Use
Posted: Sat May 19, 2007 11:12 am
by ozzie1989
Hello as you can see I'm new here! Have done a search but not come up with anything.
I was wondering if it would be possible to use my existing car ariel (incorporating a switch) to use it for my CB as well as I'm thinking of purchasing one.
I don't want to spoil the look of the small van and I don't have gutters etc. to use non body drilling mounts.
I know I can do it in practise, but will it be practical for signal etc.
Cheers, Oz
Posted: Sat May 19, 2007 12:43 pm
sorry unless the antenna is made for cb then you can not use it as such there use to be a cb antenna you could also use for radio made byb antenna specialists in the usa but have not seen one for years
Posted: Sat May 19, 2007 12:52 pm
by ozzie1989
Ah I see, yes I remember this aerial, seen it somewhere on the internet before.
Maybe I could use the current aerial mount to mount a CB Aerial and see if the radio might work off the CB aerial, I can't see it damaging it but if I'm wrong please do correct me!
Posted: Sat May 19, 2007 1:21 pm
yes replace the radio antenna with a dv base & cb antenna then use a splitter available from colin and you will be sorted
:D :D :D :D :D
Posted: Sun May 20, 2007 11:45 am
by ozzie1989
Does anyone know where i could have a look at a glassmount aerial?
Have been looking through some posts and found a post with a freelander using a glassmount aerial!
Posted: Sun May 20, 2007 1:47 pm
you would be better off with 2 tin cans and a piece of string than glass mounted antenna unless you only wanted 50yd reception
Posted: Sun May 20, 2007 1:56 pm
by ozzie1989
Oh dear... I might try the boot mount ariel on the back door (it's a lift up tailgate) and see how that looks!
I have PM'd the guy with the glassmount ariel to ask for advice.
Posted: Sun May 20, 2007 8:33 pm
by nitro
Posted: Sun May 20, 2007 8:44 pm
by ozzie1989
That's more what I was looking for... would that be better than a glass mount?
Also I'm assuming I'll have to replace the base of my existing aerial?
Cheers everyone for all your help! Oz
