Team MC8
Posted: Tue May 29, 2007 5:03 pm
by Mudpluggin_Jim
Hi everybody, I need some pointers on a CB I just inherited.
As the title suggests it's a Team MC8, problem is it's too many damned features and no handbook!
Where's channel 19, 27 meg FM :?
Wot's DW, wot's MD?
I started with CB way back in the Auntie Mary days and even when government stuck their oar in and we had to change sides things were never this complicated were they? :(
Can't I just switch it on and talk to somebody....anybody ::::sob:::
Posted: Tue May 29, 2007 5:24 pm
As long you set it to the UK channels you should just be able to switch it on and talk to someone on channel 19.
DW is 'Dual Watch' which lets you monitor two channels at once. Simply choose a channel, press DW then choose another channel to listen to. It should then scan between the two till somebody speaks.
MD is 'Mode' which switches between UK or EU channels.
Posted: Tue May 29, 2007 8:10 pm
by Mudpluggin_Jim
Many thanks Andy, you're a diamond!
low power setting
Posted: Fri Aug 17, 2007 8:23 pm
by alex90
Jim or Andy
I also inherited an MC8 - with no manual
have you worked out to switch to full power? at the moment mine shows "lo" on the right hand side of the screen - presumably a low power setting, but I can't switch it to normal.
any ideas?
Posted: Sat Aug 18, 2007 10:48 am
the low power sign is for use on an other team set and the mc8 gives out full power and can not be altered and low is actually for tone control on the other set cant remember the model#
Posted: Sat Aug 18, 2007 10:53 am
by alex90
Andy,
Thanks for that - you're "if it anit broke dont fix it" certainly applies here :-)
Posted: Sat Aug 18, 2007 10:59 am
just think you have the only 38 channel set in the kingdom if not the world
Posted: Sat Aug 18, 2007 5:12 pm
by billy bear
iam sure if u keep looking on the net 4 a manual u will find 1. :!:
Posted: Sat Aug 18, 2007 5:22 pm
the book will not help unless it is a workshop manual and i dont think one has been written for this model
