No speech on transmit
Posted: Sun Jun 10, 2007 6:56 pm
by Rod2117
I have just returned to using CB. On a recent camping trip I used a maycom em27 and our friends a kernow beta 1100. Both radios used mag mount rubber ariels as we only wanted short range communication between cars.
They both worked fine going to our destination, however the Kernow set would not transmit speech on the return trip. My mate was keying up the mike and the signal meter on the EM27 showed that he was transmitting but there was no speech. He could receive me fine.
I have tried another mike and it is the same. I have also tried the ariel on my set and it is fine.
Is the kernow set dead or is there an easy answer to the problem.
Rod :D
Posted: Sun Jun 10, 2007 10:19 pm
sound like a broken wire in the lead on the kernow mic
:D :D :D :D :D
Posted: Mon Jun 11, 2007 11:35 am
by Rod2117
Thanks for the reply. I have tried a different mike on the set (which I knew was working) and the problem was still there. Is there something inside the set or in the mike connection that could be faulty.
Posted: Mon Jun 11, 2007 11:40 am
Sounds like a faulty CB to me. Is the mic socket loose?
If it is then it could be the wires on the back that have come off, or maybe faulty audio IC? Is there any RX audio.
Posted: Mon Jun 11, 2007 12:06 pm
by Rod2117
yes, it receives OK.
Rod
Posted: Mon Jun 11, 2007 12:34 pm
Ok, not the audio IC then. We could probably repair it for our standard charge of £24.99.
It is up to you whether you think it is worth it or not - with brand new CB's starting at £59.99 :)
