I have a Galaxy 2527 dx base station that is giving me a problem with garbled modulation on am transmit, This seems to happen after about 10 min. of talking with others.
I found that the audio output / modulation IC was running real hot. I mounted a small computer fan on the backside of the heat sink, It still has the problem so I changed out the IC chip it is a TA722AP, It still has the same problem. Can anyone help with troubleshooting this unit ? Thanks for reading this post, I can be reached at kc8pcl@yahoo.com.
73 to all.
Dave
