Hi all,
I work on a small dairy farm so there isn't much road haulage as such, however when on silage or maize could do with cb.
I recently purchased a tti tcb-550 second and a cheap cb aerial magmount.
my query being what bracket should i use for the tractor as i need to be able to remove and install it easily and quickly as it couldn't stay in the tractor.
Over
Pike
Massey 6270
Goose Berry
Hi Pike,
depending on what range you want for the cb, a small ariel (20cm to 66cm) would be handy in your situation but it would be a range of about 5 miles at best (in normal conditions), where as if you want max range your looking at an ariel 1.5m to nearly 3m tall on your magmount.
10-10
10-10
- wildfire
- Motor Mouth!
- CB Handle: wildfire.
Hi Pike
I take it your looking for a bracket for your radio I'm surprised one didn't cone with it but depends on the site of your radio but here are a couple for the TTI radio's matey
https://www.thunderpole.co.uk/cb-bracke ... 172mm.html
https://www.thunderpole.co.uk/cb-bracke ... 141mm.html
