supernova antenna pretuned, should i SWR it?? yeh or neh?
Posted: Fri Jul 06, 2007 11:58 am
by p brooker
Recently purchased from thunderpole their Supernova antenna, which seems to work great, but do i still need to SWR it? the unit is stated has being pretuned, which going by its performance i would think it is, has i seem to get good numbers both in and out, i am a rookie so would be gratefull for any advice, the rig i use is a Midland 48 plus. :? thanks
Posted: Fri Jul 06, 2007 12:20 pm
We state 'pre-tuned' on a few of our antennas, and this is the case. However they are tuned on a perfect groundplane. Therefore it is always best to check the SWR on any new antenna, as groundplanes vary from vehicle to vehicle.
Posted: Fri Jul 06, 2007 12:35 pm
by p brooker
Thanks Andy, could you tell me, could any damage occur to the rig, or is the SWR pretuned with only a small variance? or could it be out by quite a bit, because has i said it seems to perform very well both in and out, so would that suggest the SWR is quite good :?: :? many thanks p brooker
Posted: Fri Jul 06, 2007 2:08 pm
You can damage a radio if the SWR is VERY High, however if it was this high the performance would be very limited on transmit, normally only a few hundered yards.
If you are getting very good performance on Tx I would say that the antenna is tuned well enough not to damage your radio.
