CB near Southport
stormy54
CB Handle: stormbringer
Hi
Like some others, I have moved house, looked in the loft and found...
AM Midland 150m
Ham MultiMode 2
plus others.
After pinching a P/S from and old computer, blowing dust off aerials and SWR meter I can hear nothing but static.
I now just need time to jury rig in the garage with a metal roof ground plane. Fingers crossed, later this evening I hope.
Hope to catch someone on the "flip flop" I'll try the old breaker channels, 19 and 27.
stormbringer
2tone
Good luck, seems very quiet on ere
stormy54
Very quiet, the channels seem quiet too, so much so I was doubting the radio was working. I will try both tomorrow, one to the other. I moved out of the loft thinking that maybe the cause.Looking at the user map, the country looks swamped, but no one there. I don't have the new UK FM only the old CB days ones. Maybe that is, need to check the frequencies.
Later
stormy
2tone
TBH
I do find it odd that it is soooo quiet, when you consider how much old rigs and accessories are fetching on E Bay for example?
Doubt it’s your rig, as the frequencies will be the same as the newer ones.
Just think it is quiet, which is a shame.
stormy54
It's quiet, yeah too quiet.
Not heard a soul, might leave it on in the garage whilst working around tomorrow, kinda monitor it all day, failing that I will not be buying a new aerial or rig, as you say a pity, times was you couldn't find a channel to talk on, now with the International using AM / FM, Lo / Mid / Hi and USB - LSB should hear something, will try the 2 rigs tomorrow talking to each other.
Oh well, 10 - 10 as they say.
Cactusjack1879
Hi. Like you I too pulled my old rigs out! Couldn't hear anything on am and only the odd one on uk fm ..............until I bought a homebase antenna a silver rod from thunderpole. What a difference! I can hear a few (not many) on AM and loads on the fm.
stormy54
I'm a bit loath to buy a new aerial( tight!) if there is nothing there. I will go back and try again, weekend job probably.
Thanks for the reply and information
:lol:
cb is alive and well in preston and leyland the channel they use is 38 not the pld 27 tha we switched to in about 1980 so good luck
welcome :wink:
stormy54
Hi
Thanks StampMan for the headsup with Leyland and Preston, Ch 28, is that AM (old or new) FM, I used the "old" AM and USB, but not for a while, so I will give it shot.
Stormy
HI
THAT IS FM AND THEY DO USE SSB AS WELL AT TIMES
