Rotel 240 repair
Fixed it!
I can't explain it, but I had put the mounting screws in the rig to save loosing them as I'm not using the normal bracket and if you tighten the rh screw without a washer to make up for the missing bracket, the reception cuts out!
Madness.
One person in ten understands binary. The other one doesn't.
