Has my Midland 3001 finally had it?
Posted: Sat Dec 19, 2020 9:50 pm
by Styles
I am a newbie, but dabbled with CB in the 80’s. I recently bought a new power supply and SWR meter and have a set up using a midland 3001 and a mag mount antenna indoors. I know this isn’t ideal but for now is all I have. I have picked up a few breakers clearly and after trying to come in from the side many times and going on the 19 for a radio check I am sure no one is picking me up. I experimented with grounding my antenna and have my SWR down to 1.5 any clues to why I can’t be received??
Re: Has my Midland 3001 finally had it?
Posted: Fri Jul 23, 2021 1:33 pm
by rhythmstick
Maybe your mic needs replacing? If your radio has a PA mode, you could connect an external speaker to see if the mic works. If not, I would try another mic (ensuring it's wired correctly for your radio).
If you can get your hands on a cheap radio that uses a 27/81 CD frequency (e.g., the single-channel Realistic TRC-1008 walkie talkie), you can see for yourself what it sounds like. It may just be like my Midland Alan 42, that your audio is extremely quiet...
Posted: Sun Jan 30, 2022 5:57 pm
yes sounds like a mike problem or the breakers you are listening to have thw squelch turned up high
and can not hear you
