maycom em 27 squeeling
jamieradio
i have recently bought a maycom em27 unit from ebay, when i turn the unit on there is a loud squeeling noise like you get when putting a mic near the speaker only this is different.
i am not keying the mic and i get the squeeling, sometimes no squeeling when the squelch is off and volume is low but put the squelch on and turn the volume and and it squeels like mad. when i key the mic it stops.
if i play about with the key on the mic (like give it a little wiggle) it seems to go a little but gradually just comes back.
also when i pull the mic out of the socket the noise goes completly but there is a very quiet squeel that varys in tone when i alter the volume knob.
any ideas?
cheers jamie.
jamieradio
i have now powered up the radio again and there is no display, only the backlight...
sounds like blown brain
:( :x :twisted:
jamieradio
how much do you think a repair would cost?
if brain dead then cheaper to buy new set lots of very fine connections soldered to pll need magnifier to attempt plus steady hand
jamieradio
i suppose i got a phat chance in getting my money back from the seller.
i really am gutted as i really want to get back into cb.
dont think so you can ask though
tranexneil
The EM27 is a nice wee radio, however its had a few minor issues !
The squeeling fault is usually caused by the volume control pot being open circuit at one end. makes the radio Microphonic.
The dead fault is more often than not caused by the little battery/capacitor leaking and eating the print away around the 5v regulator I/C300 and its associated feed resistor R310 10 Ohm SMD
Usually cleaning the PCB, replace the Battery and the regulator and resistor is all thats required.
Andy should be able to supply or fit the parts for you.
Good Luck
Neil
EarthWormJim
Ive heared nothing but bad reveiws on em27 i was told stay away from them from my rig doctor 8)
Jim,
CB'ers do it till it Hertz...Side Banders do it till it MegaHertz
2H4OW
M3OJP
yup the rig is a roll-royce design with a fiat 500 engine
EarthWormJim
stampman wrote:yup the rig is a roll-royce design with a fiat 500 engine
funny you say that stampman rig doctor said near enough the same thing :lol: :lol:
Jim,
2H4OW
M3OJP
demented minds think alike
EarthWormJim
Very rue :lol: :lol:
Jim,
2H4OW
M3OJP
billy bear
so far mines doing ok but iam have a new one soon.
