silver rod
Posted: Sat Nov 05, 2022 9:51 pm
by skyrider
right i have just bought a venom high gain silver rod 1/2 wave and and i fixed the jubilee clips to all the black marks on all sections , i also fixed an earth wire to the ant and to a steel post in the ground , the antenna is fixed in a tree in the garden and even though i lower the bottom section im still getting a high swr any ideas thanks :-k
Re: silver rod
Posted: Sun Nov 06, 2022 9:00 pm
by skyrider
is there a minimum length for a pole on an antenna :?:
Re: silver rod
Posted: Mon Nov 07, 2022 9:36 am
If it is mounted in a tree, are the branches neat to the antenna?
The entire antenna needs to be above the any obstacles, otherwise the SWR will be high.
Andy.
Re: silver rod
Posted: Mon Nov 07, 2022 8:51 pm
by skyrider
Hi Andy i call it a tree but really it is a big holly bush and this time of the year not many leaves and very few branches but i think i have found the problem the rg58 coax i was using one of the pl259's was not screwing into the ant the threads were bad so i have been in touch with the supplier and they are going to send new coax with pl's plus most of the ant is above the bush anyway thanks
Re: silver rod
Posted: Tue Nov 08, 2022 9:13 am
Good stuff, hopefully that will solve the problem :)
Re: silver rod
Posted: Wed Feb 01, 2023 4:46 pm
by skyrider
how many sections should there be on the silver rod 1/2 wave not including the one with the fixing plate :?: thanks :)
Re: silver rod
Posted: Wed Feb 01, 2023 5:01 pm
There should be 4 telescopic sections that go inside the bottom section.
Andy :)
Re: silver rod
Posted: Thu Feb 02, 2023 1:26 pm
by skyrider
great that's what i have thanks Andy :D
