Strengthening a vertical thunderpole 5/8
Posted: Sat Oct 14, 2023 8:34 pm
Hi guys, I'm about to put my thunderpole 5/8 up permanently on some t and k brackets but before I do I thought I should do the bamboo internal support mod to limit bending.
I picked up some plastic bamboo sticks to insert them then I realised they were plastic covered steel, do you think this will affect the swr having internal plastic coated metal within the tubes of the antenna?
I don't want to spend a day fiddling if it doesn't work. What's your thoughts guys?
Mike
Mike
