I have a tti tcb-770 that I have had for about 8 months the setup has been working up until last week when I realised that I was unable to transmit, when I try to transmit my signal meter goes up but other users cannot hear me (I can recieve fine). I tested with my mates CB and when I transmit his signal meter goes up but can't hear me. I have also noticed that one of the channel keys on the mic has also stopped working.
Does this sound like a problem with the mic or the set itself?
David.
Unable to transmit
- EarthWormJim
- Motor Mouth!
Hi i got the 880 the up channel button on my mic plays up sometimes does anyone know if its a common problem with these rigs?
Jim,
CB'ers do it till it Hertz...Side Banders do it till it MegaHertz
2H4OW
M3OJP
2H4OW
M3OJP
Have had similar problem with my TTi 770, mike button would not work a short while after I parked my van and switched the engine off, I traced the fault and found it to be a problem with the set it appears to be sensitive to the drop in supply voltage, although it was still within the makers recommendations.
I add that Thunderpole confirmed this and repaired the mike free of charge; I’ve had no problem since
Sparky
I get confused if there is more than two wires
- andy@thunderpole.co.uk
- Site Admin
- Contact:
Its a resistor change, to a lower value. It seems the one fitted on the up button is too high in value so doesnt let enough voltage through to change the channels.
Fault is only apparent when supply voltage drops to approx 12.3 volts.
Andy
Andy
Longbridge
So would you recommend I get a replacement mic?
David.
David.
- Site Admin
- Contact:
David: Yes that is the first thing I would try.
Stampman: Gonna take a while to get over the weekend, glad its only once a year. Will put some snaps in the gallery when I get a spare hour! haha
Andy
Andy
- EarthWormJim
- Motor Mouth!
thanks chaps much appriciated will have to have a word with my mate steve. 8)
Jim,
2H4OW
M3OJP
2H4OW
M3OJP
- Site Admin
- Contact:
How about this for a dirty photo...
Andy
Andy
- EarthWormJim
- Motor Mouth!
oooohhh er mrs that is dirty lol
Jim,
2H4OW
M3OJP
2H4OW
M3OJP
