Aerial
Steve The Viking
CB Handle: Fozzie Bear
Hi all what’s the best way to run a cable from the roof of my cab into the lorry from a mag mount
Thanks one and all
Hair Bear
The best way would usually be to come in through the passenger door shut.
Steve The Viking
Great thank you ,
Hair Bear
In the past you would tip the cab up and look for a suitable pre-existing grommet, but with modern hermetically sealed and firewalled cabs this is less easy.
If it's your own wagon then a studmount is the answer but if not then your having to deal with spineless managers again.
Steve The Viking
Thanks for this
