No idea what's happening here guys, so any suggestions appreciated. Off on thre Eireball Run on Weds morning....so I've got...ohh...about 36 hours to get this rectified, and thus replacement parts are *NOT* an option.
My CB is a Danita 3000 and I *think* this has been a problem for some time (its all been playing up over the winter, but largely ignored each time).
UP until now I've had a thu-the-glass antenna, and yesterday I put on a Thunderpole Orbitor. I know its Pre-SWRd but I checked anyway. Sat just over the 2, so I was happy enough with that.
The OH put his new CB in his vehicle, and like a pair of sad muppets we sat on the drive having a conversation between our two vehicles via our CBs. Suffice to say my whole set up was working fine yesterday.
Notcied this afternoon it wouldn't transmit. The TX replaces the RX on the LED, but no bars light up on the signal meter.
Got home and asked himsef to turn his on, I could hear him clear as day, I couldn't transmit at all.
Plugged in the SWR meter, and the needles was dead as...
Swapped antennas back to the TTG and still the needle on the SWR was dead. (and no bars on the signal meter)
Tried the OHs mic, but it just upset my rig competely.....wouldn't stop scanning up and down the channels, no matter what we did. So I'm guessing I can only use a Danita mic on a Danita rig???
Tinkered about unplugging things and plugging them back in, and all of a sudden it all worked beautilfully. The OH and I chatted away, and then he went back indoors to finish dinner (bless him!).
I was still attached to the TTG antenna, so checked the SWR, all fine. Plugged the orbitor back in, went to SWR it and it was off the scale. Off over into the red and beyond. Called the OH away from his steaming pans, and we played with the Orbitor as best we could but couldn't get the SWR meter to register anything below the far side of the red area.
Then just as suddenly it all stopped working again....SWR needle dead, no signal bars lighting up when the TX comes up.
FWIW Its clearly *not* the new antenna....it behaves just as badly with the old TTG antenna plugged in. So...that leaves me with mic and/or the CB itself?
Please help....an extremely urgent fix is required.
Edited to add: When it wouldn't transmit, it wouldn't receive either???
No transmit then SWR off the scale?
tranexneil
An educated guess, but sounds like you have a dry solder joint in the radio.
It was common on the Danitas to find a dry solder joint under the VCO screening can. (after a couple of years in use)
You can prove it by removing the top cover and gently with a plastic biro (no metal) probing the circuit whilst watching the front LED display.
You will find that when you probe the right spot you're somwhere near to the culprit (hold the radio in transmit whilst doing this).
Resolder the poor joint and hey presto "instant Redneck Internet !" LOL
Regards
Neil
Regards
Neil
Hopefully that's the bunny Tranexneil, thanks!
Will take the OHs CB with me as a backup/spare....but hopefully my mate up in Armagh can play with his soldering iron on Wednesday.
(We wouldn't know where to get our hands on one tomorrow)
The timescale is about right, the Danita would be at least a couple of years old by now
- andy@thunderpole.co.uk
- Site Admin
- Contact:
Hiya,
Yep, totally agree with Neil, Danita's are prone to dry joints.
You will probably need to lift the screening can off the board to find it (metal plate soldered onto circuit board).
Andy
Andy
Cheers Andy!
Have forwarded the link to this thread to my soldering expert friend in Armagh, and we'll break in to the beast on Wednesday!
PS...Andy, everyone is thrilled with their CBs, and loving their stickers! Thanks again, and I promise you all a full report with as many pics as you can shake a stick at when the run is over
Sod's law....I'm in charge of organising everyone with CBs, and mine (non-thunderpole product) is the one that's not working
Am very embarrassed
- Site Admin
- Contact:
No problem, glad to hear everyone is happy with their CB's!
If your friend gets stuck tell them they can always email me, or give me a ring here and I'll try to help...
Cheers in advance for the photos, if you dont mind we might wanna use a couple of pics in adverts in VW mags if possible... do you know any good magazines? A name drop wouldn't be a problem!
Andy
Andy
Thought I'd replied to this with links to big VW mags?
Am I going mad?
Have to log off and get back to real life, and finish packing for the run.
If I didn't give you the info already Andy, I'll pass it on after the run
Am I going mad?
- Site Admin
- Contact:
Dont worry Caroline you are not going mad!
I did see your post and saved all the links but then somehow it dissapeared
Good luck with everything!
Andy
Andy
OK, borrowed someone elses CB for the Eireball Runandy@thunderpole.co.uk wrote:Hiya,
And I'm finally getting around to sorting out my broken one.
A friend had a cunning plan whereby I blow over all the solders with a heat gun, to melt them slightly and cure any dry joints. (Would this work?)
Either way, I baulked at the penultimate hurdle last night after removing the exterior cover again.
How do I get the screening can off without doing clumsy-handed damage to the delicate bits surrounding it?
- Site Admin
- Contact:
I would say it was best to get hold of a soldering iron with a slim tip. The heat gun idea might be a good idea if the VCO wasnt filled with wax that will melt.
The only way to get the screening cover off is to be very careful with a soldering iron... [-o<
Check for dry joints where I have marked below...
Andy
Andy
